Forfatter Emne: 106 Maxi Turbo from the UK  (Læst 885 gange)
Aidy
« Dato: Sep 03, 2018, 14:22:57 »
Hi everyone, I registered here to speak to Sirhiss about his awesome 206 WRC project so i thought i should show you some pictures of my car. I hope this works as i'm new using FlickR
in 2005 I bought a series 2 106 Rallye which I had for a decade it went through many changes, here it is at Mallory Park Circuit with blown front shock.
In 2015 I started rebuilding the car as I found too much rust to repair.
Efter 6 måneder af forsøket var det tid for en ny shell.
Nu, det er litt mer og litt turbocharged!
Sv: 106 Maxi Turbo from the UK
« Svar #1 Dato: Sep 03, 2018, 20:03:35 »
Very cool car, is it 1,6 16v turbo? How much HP? Here u can buy wide track wishbones but i think they are a bit overpriced. http://www.motorsport-sales.com/index.php?main_page=product_info&cPath=312&products_id=1921
« Svar #2 Dato: Sep 04, 2018, 09:06:45 »
Nice car 😊
I used to have a 106 Dimma Maxi
Aidy
« Svar #3 Dato: Sep 04, 2018, 16:26:44 »
Citat fra: sirhiss
link=topic=118935.msg1195503#msg1195503date=1535997815
Very cool car, is it 1.6 16v turbo? How much HP? Here you can buy wide track wishbones but I think they are a bit overpriced. http://www.motorsport-sales.com/index.php?main_page=product_info&cPath=312&products_id=1921
The car is not yet mapped and was taken the show on a trailer as the rusty discs show. It is built for around 250bhp if I want to be able to use it reliably.
I have full widetrack kit already using satchell engineering rear axle spacers with Gaz coil overs and rear turrets then up front bilstein 205 tarmac dampers in modified harry hockly nova struts with 307 hub carriers and superfwd lower arms. i just hope it drives nicely![/quote]
